Date should have option to set current date as default
it will be good if it is possible to set current date( not the specific date)  as the default value for the date attribute in windchill
4 Comments
BenLoosli
23-Emerald I
Explain this in more detail. Windchill currently uses the system date as its default current date.
Where are you seeing another date that is prompting this request?
BineshKumar1
We have a requirement where we should be able to put a constraint that the user should not be able to select a date before today's for the attribute
ShirishMorkhade
Hi Binesh,
If you want to disable past days selection in calendar picker, then you might want to follow below instructions:
  1. Update initCal function in <WT_HOME>\codebase\netmarkets\javascript\util\calendar.js
function initCal(_title, _stylesheet, _trlUtils, _dayPos, _monPos, _yrPos, _monLabel, _yrLabel, _disablePastDays, _numYearsToShow, _startingYear) {
  calTitle = _title;
  calCss = _stylesheet;
  trlUtils = _trlUtils;
  monPos = _monPos;
  yrPos = _yrPos;
  dayPos = _dayPos;
  monLabel = _monLabel;
  yrLabel = _yrLabel;
  disablePastDays = true;
  numYearsToShow = _numYearsToShow;
  startingYear = _startingYear;
    2. Run ant -f bin/jsfrag_combine.xml from a Windchill shell
    3.  Restart Windchill Method Server
    4. Web browser cache may need to be cleared to see changes
I hope this helps you.
Shirish
olivierlp
Community Manager
Status changed to: Archived
