Hi There,
I imported a 3D model to Creo Illustrate through Import>Link. I created sequences by moving different parts of the model in each step.
As of now I am required to delete the sequences for parts that are deleted which is almost impossible due to the complexity of the illustration with overlapping sequences. |
