When you have an expanded View of a structure in the Save as Dialog and you select one element. then ALL elements with that item Number will also be selected.
if yo deselect one of them all others will be selected.
We use this function to create new WT-Parts in one shot.
The parts will be now created an will be replaced in all structure Levels where there are built in. That is not the goal.
So the idea is to select only ONE dedicated structure item and handle only this item with the commands.
Maybe to do so ist to press STRG Key
