The US Government may impose an Export Restriction on data for various reason. In addition, Proprietary restrictions also are required by Parker Hannifin.
The need is to control access to data, based on employer, employer legal residence, and user legal residence.
By default, all Parker US data should only be shown to Parker Employees with US Legal Residence.
After review of data by our Export Control Administrators, data can be shared.
For demonstrations' sake, allow a minimum of three categories of data. And arbitrarily, 5 groups of people with unique authority to export.
Categories of Data
1) Parker military use restricted data, 2) Parker technologically restricted data, and 3) Parker propriety data.
People Groups
a) Parker US, b) Parker Foreign National, c) Vendor US, d) Vendor CA, e) Vendor foreign national with exception license to see Project C data
Data Organization..Existing
Project A - access set or all
System A Parker Proprietary data
System B Parker Proprietary data
Project B - access set for a) Parker US
System A Parker Military data
System B Parker Military data
Project C - access set for a) Parker US, e) Vendor foreign national with exception license
Project D - access set for a) Parker US, d) Canadian Vendor
This would require an administrator to create a Project for every program and data type. Also requiring users to create systems in the correct project.
This Product Idea would be our ideal solution
Administrators would create a Project for Category of Data
Engineers would then create a System, which inherits access from Project, for each program in the appropriate Category
1) Project - Parker military use restricted data with permission for .. a) Parker US
System -program A, permission inherited
System -program B, permission inherited
2) Project -Parker technologically restricted data with permission for ..a) Parker US, c) Vendor US, d) Vendor CA
System -program C, permission inherited
System -program D, permission inherited
System -program G, permission inherited
3) Project -Parker propriety data with permission for ..a) Parker US, b) Parker Foreign National, c) Vendor US, d) Vendor CA, e) Vendor foreign national
System -program E, permission inherited
System -program F, permission inherited
System -program H, permission inherited
When an exceptions is granted to system/program by export administration....
System -program B, a) Parker US, e) Vendor foreign national w/ exception license for program B
Since there are dozens of programs and only a few categories of data, system administration is kept to a minimum. (few)
The engineering community could minimize adherence efforts as systems would default to the correct access. (dozens)
Export administrators could manage licenses on data without the need to move or create a new Project for each exception license granted. (hundreds)
