1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What version of Windchill are you currently running?
12.0.2.3
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
Upon importing EPM document in workspace Windchill created attributes with default values should get pre-populated.
Default values only get populated when creating new EPM document.
4. What is the use case for your organization?
Uniformity
5. What business value would your suggestion represent for your organization?
The default value are passed to ERP. So it has to pre-populated as users don't fill vague values.
