Default Context for Change objects affected objects
0 Kudos
When raising a new Change object at multiple places we have to search for and select affected objects. In the majority of cases these affected objects will be in the same context as the change object, however every time the search applies across all contexts.
It would be good if the search context defaulted to the context that the change is raised in so that the search is limited to this context.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
