The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Default UOM value for measurement is set as "cm" while creating the measurement template. But in "measurement set details page" of product it will show the UOM as set in the session variable instead of default UOM set
0 Kudos
Steps to reproduce the issue
Go to library -->Create a measurement template with default UOM as cm-->Choose any product --> Go to specification --> Click on Measurements tab --> Create new measurement set using the measurement template created in library.
On the measurement set details page the under display mode the UOM will appear as set in the session variable i.e "in"(inch) and not from the default UOM from the measurement set.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
