Different Themes Production and Testservers
Ther should be an easy way to apply different color schemes ( maybe at least changing the color of the header ) to Windchill,
so that one can easily see whether he's working on the production server or on the testserver.
This should be configurable in the wt.properties
5 Comments
SimonLucas
1-Newbie
in 9.1 we used simple a simple header image to diferentiate the systems, in 10.1 we have some customised style sheets. Both fairly straight forward.
MikeLockwood
22-Sapphire I
Some of our folks figured out that you can just edit the color of this file directly - which is what we now do in each OTB ref install or rehost.  Results in a different color horizontal band that you instantly recognize as being, production, test, DR, etc.
hlinseisen
1-Newbie
The File can be found at
"C:\ptc\Windchill_10.1\Windchill\codebase\netmarkets\themes\windchill\Header\background_gradient.png"
The Windchill Logo can be changed at
"C:\ptc\Windchill_10.1\Windchill\codebase\netmarkets\images\logoWC.png"
It still would be an improvement if ptc could provide the nescessary files themselves and make it configurable
Thanks a lot
canderson
6-Contributor
Ok I edited these files.. Nothing happened.. can someone give a bit more detail?
PTCModerator
Emeritus
Status changed to: Archived
