Possibility to disable confirmation pop-up when adding an existing part to Part Product Structure in Windchill PDMLink.
Pop up: Confirm: Child already exists. Add again? An item you are adding is already a child of a the parent.
This pop up is bothering if you add a part several times in the same BOM.
Application: Same part with different usage attributes.
e.g. parts with different length, ....
