Disable the sending of ProjectLink replacement invitation emails
It is currently possible to configure Windchill to disable the sending of project invitation emails via the property wt.inf.team.sendInvitationEmail; there should be the capability to apply a property to disable project replacement invitation emails also.   In some cases, project managers users are receiving thousands of emails when a user is removed from a project.       PTC has suggested manual deletion of email queue entries; but this is not a viable solution.
5 Comments
ScottMorris
It would be equally valuable to give these two items a user interface to allow organizations to make this an optional step when needed vs. a property change and global setting. It would be as simple as adding a checkbox to the existing UI to determine whether or not email is sent.
PTCModerator
Emeritus
PTCModerator
Emeritus
JoachimLoos
Would be good if this behavior could be configured in some fashion, e.g. via property or, better, via preference.
ScottMorris
Take a look at this CS Article, which controls sending invitations, but you are right. There should be controls for all the emails sent from a project.
https://www.ptc.com/en/support/article/CS253030
