Disabling of Automatic Update in CATIA when Publishing
The CATIA publishing process currently does an automatic update of the CATIA data. Our view is that the decision to do an update or not should be the sole choice of the designer before checking-in data to Windchill. The created lightweight data will thus be the geometrical view the designer intends to convey. In our case, in-work data is seldom updated while work with constraints is ongoing, whereas released data is of course updated. We therefore need to have the update disabled in the publishing process to have consistency between the stored native and created lightweight representations.
3 Comments
YodaKim
Status changed to: Under Consideration
YodaKim
Status changed to: Delivered
In Windchill 11.1 M020, you can control the automatic update during File Synchronization enabled CATIA worker.By default, the automatic update during file sync is still enabled. To disable it,
  • Change the autoupdate.model.upon.filesync.publishing preference to No in the wgmclient.ini file
  • Disable automatic updates in the native CATIA V5 settings for Part Infrastructure and Assembly Design
RuneDenti
3-Visitor
We've tested the settings which enable/disable the automatic update during File Synchronization and it's working as expected for our publishing jobs.
Thanks for letting us have control of this.
