No, Document Classification? is just a discussion. These two items should be linked together, but its important for people to vote up the idea. I will cross post to make sure people are aware.
Scott - Is there something scheduled around Document Classification in the Roadmap? Partslink may be dedicated to parts but the idea to classify documents would consist in applying the concepts of PartsLink to the WTDocument Item with a unified way to search objects (parts and docs) ... Business would be very much interested with such features, especially when business users are used to Partslink...
You seem to work for PTC so I hope you have a higher level of information on this topic.
From our TSAM :
Document Classification is in our future plans but quite low on our priority list (at least no chance in the near future). Sent more information to PM. [3 Oct 2016] There is quite a bit of R&D work required to enable this feature so we are hoping to be able to fund a design spike in Windchill 11.0 M030 with a view to possibly implementing in the following release. This is not confirmed yet but, if approved, this would be the soonest we could implement.
[23 Nov 2016] The implementation work cannot be done in 11.0_M030. We are planning to work on the design approach during the M030 time frame though
The release is planned for the upcoming Windchill 11.2.0.0 release. This work has spanned several releases. We will be putting some examples here shortly - stay tuned.
I have tested it and it work pretty well. Search is truly better than the one we have with our customization. It will be perfect if we would be able to classify for one attribute on many nodes at a time.
Like with the attribute "Produit" (in the screenshot), I need to link 1 attribute to many nodes.
Now, I have to : on the attribute, search the node I will link and then click Ok and re-do the same operation after creating a new instance of a "Produit" attribute linked to another node.
So I would like to be able to select several nodes at the first time and Windchill will create as many instances of "Produit" attribute as necessary.
Has it been confirmed what release of Windchill this will be on? We are very interested in this functionality, but we're planning an upgrade to the long running release of Windchill 11.1 M020.
@fpartarrieu 11.2.1.0 is a long running release as well, but its EOL is not as long as normal long running release due to timing of the Java 8 transition to extended maintenance.
