The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Document Downstream Propagation based on document type
Currently MPMLink does not allow to specify what kind of documentation is propagated to downstream branches/parts based on document subtype. In fact there are kinds of documentation which are not needed for manufacturing purposes, so it would be beneficial to really only propagate those document links which are related to the equivalent downstream branch/part.
The current properties only allow to define the link type, meaning that whether all or none describing (Described_by link) or referencing (reference link) documents will be linked to downstream branch/part. Being able to differentiate between specific document subtypes it would be necessary to subtype the links (Desribed_by, reference etc.) which is not an option.
Furthermore it should be considered, that the property is also reflected in other MPMLink functionalities, such as reconciliation assistant/Update equivalent link with propagating upstream changes to downstream or automatic BOM transformation (GDS).
2 Comments
olivierlp
Community Manager
Status changed to: Clarification Needed
Thank you for publishing your idea. However, we need more information as specified in the form you saw in the submission process. (questions below). The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
Please let us know within the next two weeks.
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What product & version are you currently running?
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
Additionally, I invite you to check out this topic where 2 PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
olivierlp
Community Manager
Status changed to: Archived
We are following up on our request for additional information on your idea. In the absence of further comments from you, we are archiving your idea. You still have the option to post a new idea with all the details required.
Thank you.
