Document Structure Loading utility should allow multiple child under 1 parent in input file
0 Kudos
Please include detailed documentation such as screenshots, images or video.
1. What version of the software are you running?
Windchill 12.0.2.7
2. What is the problem?
While loading document structure, in csv or xml input file child need to be mentioned in separate lines or arguments.
For example, there are two documents Doc_001 and Doc_002, that we need to add into structure of Parent_Doc_001. Then xml input file would be like
<NmLoader>
<csvStructureLink handler="wt.doc.LoadDoc.addToDocumentStructure" >
<csvparent>Parent_Doc_001</csvparent>
<csvchild>Doc_001 </csvchild>
</csvStructureLink>
<csvchild>Doc_002</csvchild>
</csvStructureLink>
</NmLoader>
Instead of that it should be someting like
<NmLoader>
</csvStructureLink>
Due to this input file will be less complicated.
3. Are you using a workaround? If yes, please describe it.
No, there is no workaround.
4. What is the use case for your organization? Describe how your idea would work in context or how it would apply to a practical situation.
In our organization, we want to do this for large dataset. The current functionality increases the input size and complexity.
5. What impact does this problem currently have on your organization? (Number of users affected, hours of lost productivity, etc.)
1 Comment
achirila
Moderator
Hi @Vipul_Limbad!
Thank you for your idea. Based on the information you provided, we are acknowledging it as the Community management team. This is not a commitment from the Product team.
However, we ecourage you to add a little bit more information regarding the current impact on your organization.
Other users may comment and vote your idea up.
