Current behaviour:
We are able to link one CAD Model to several Parts with owner link. In this case it's not possible to Check in data if the set up is defined to automatically generate associated BOM.
So if we want to pilot Part structure from CAD structure we need to have one CAD per Part. As we can manage one CAD for 10 or 15 Parts, it's a huge effort to manage the same number of assembly.
Expected behaviour:
In case of conflics we should have an error/warning message to invite user to select the correct Part we want to use in the BOM.
If we can have one CAD for several Part, it will be easier to collect "use cases". Change management will be improved.
