Duplicate function in MAPSB does also duplicate Process Plans & Operations, but does not create the copies in the same context as selected for the duplicated parts. Instead the copied Process Plans & Operations are stored in the originating context.
Result: today users are lost of where the copied Process Plans & Operations were duplicated. Users can move the process plan to another context later by a move action on folders page, where it is very difficult to select exactly the correct Process Plans & Operations. This is counter-intuitive and very counter-productive.
At least the user should have the option to indicate that related Process Plans & Operations should be duplicated in the same context location as the Parts (it should be the default).
Even better would be to have an additional option to select a location for duplicated Process Plans & Operations.
