Dynamically Name Additional Files
In Windchill 10.2 additional files can be generated during publishing.  Currently these files are named based on the prefix, suffix (optional), and object's name.  I would like the ability to dynamically pass attribute values (in this case revision) to the suffix and/or prefix.  Right now the files for every revision are named exactly the same.  Dynamically appending the revision to the file name would allow us to identify which file goes with what revision after downloading.
4 Comments
jcremillieux
1-Newbie
The same idea exists with "Additional published file types naming convention" label
gmehta
We are looking for the exact same thing for additional file types (STEP / PDF etc)
I really hope PTC can implement this soon. The publish worker already has this info from WC to publish so why not just add it to the published file name.
This would stop a lot of mistakes when sending files to customers / suppliers and even to internal users.
Gagan
7-Bedrock
Good Idea Tom
PTC can include this option , this saves lot of time , also , it is good if they include mass export option from work space to different format from the work-space
PTCModerator
Emeritus
Status changed to: Archived
