Windchill ECAD Workgroup Manager Enhancement Request:
It should be possible to add (Checkout) an ECAD Schematic design to a Windchill workspace and allow several users working on the same schematic but on different sheets simultaneously.
Large ECAD Schematic projects/sheets are typically developed through several ecad engineers. Typically there are working in parallel on differents ECAD sheets but within the same ECAD Schematic design.
