I think the FMEA format builder of WQS should be same functionality of Excel to show and hid the column.
So that Excel customer can easily move to WQS FMEA.
I recommend you to add 2 selections as follows.
① Do not show Column
Right click of the Column and select "Do not show Column" then you can hid the column.
②Show Column
Select the 2 columns where the hid column is located, them Right click of Column, Select "Show Column" then you can see the hid column.
These functionalities are like Excel functionality.
Thank you.
Yoshi
