When I want to edit association between CAD document and Part object, if the part object is not already checked out, Windchill makes auto check out to proceed with edit associations. After the relations are done and I close the window, then I must to check in the part object to save the relations. This task is not common, then the user can forget to check in part object. Therefore, I would like to have an operation preference related to edit association to be able to set the auto check in after close the windows.
Could be possible to have this customization?
Thank you in advance.
