Edit Promotion request to delete WTObjects (WTPart, WTDocument, EPMDocument) once Promotion request is created.
In case if if user added a WTObject to Promotion request once Promotion request is created Windchill PDMLink will not allow any role including administrators to update the promotion request to delete unwanted WTobjects which were added wrongly.
Workaround will be deleting Promotion Request which will result lost of history for other WTObjects which were included in Promotion request and another solution is updating the database which is not recommended as best practice in any PLM implementation as this is will be very frequent.
Please refer to:
