Attributes of Dynamic Document objects should be easily editable directly from within the Information Page of the object just like Documents (WTDocuments): there should be an action called "Checkout and Edit" which should open a form to change the attribute values of the object.
The same action should be available in the folder view in the context menu.
From within the folder view it should also be possible to select multiple Dynamic Document objects and perform an "Edit Multiple Objects" action.
And finally, from the search results it should be possible to select multiple Dynamic Document resulting objects and change a set of attributes in bulk (change the value of attribute A to x, attribute B to y, and attribute C to z for any number of selected objects object and any number of attributes).
