Effectivity As An Attribute in Reference, Uses and Member Links
Problem:
Effectivity is only applied in WTPart as modeled extension.
Top product model always has an effectivity from birth to death/end-of-life.
Solution:
Effectivity values placed in parent objects links to children objects from the affected and resulting tables during change notice/activity lifecycle approval process.
All objects have a revision and has an effectivity (CMII with document impact matrix)
  • WTPart BOMs
  • WTPart components
  • EPMDocuments:
    • drawings
    • models
    • etc
  • WTDocuments
Result:
Drill up or down.
5 Comments
GregoryPERASSO
There's this kind of feature in A&D module ... and WTdocuments are planned to be effectivities manageable in 10.2 if I remember ...
JeffZemsky
Effectivity on Document has been supported since 10.1 M010.  When you set the effectivity and look at the product structure if the document is a References link it will resolve based upon the Effectivity.
Effectivity on EPM is a deeper discussion - why would be it be different then the part its related too?
GregoryPERASSO
Agree with Jeffrey
The CAD "is just" a desciptor.    Windchill is partcentric
gshankaraputhra
2-Guest
How about Manufacturing unit based effectivity?
Two factories manufacturing same product (uses the same WTPart) with different Manufacturing drawings.
They want to use different effectivity for their local drawings.
Any bright ideas please, how to achieve this?
PTCModerator
Emeritus
Status changed to: Archived
