Embedded browser "Checker" built into workgroup manager
WE have lots of trouble properly configuring the embedded browser within wwgm. There should be a button or menu option within wwgm called "check browser configuration for optimimum performance and reliability"
when the user invokes this feature the wwgm will scan the local install of wwgm and report to the user suggested fixes to known browser problems. The feature should give check boxes so that user can choose which fixes to implement and then make the change If desired. For instance, "reload page every time I visit it" should be set by wwgm, etc.
this tool should communicate with the knowledge base so that as new wwgm problems become known the tool gets updated and can report new fixes as they become available
PTC's choice to use an embedded browser rather than writing local client code is a burden for customers and to PTC support. This tool would help to address this problem.
2 Comments
DomenicLaritz
Barry, I recommend, that you vote up your own idea! Or do you think it's a bad one?
And because you forgot to vote for your own idea, please vote up that one too:
When creating a new product idea, it automatically adds a positive vote for the creator.
PTCModerator
Emeritus
Status changed to: Archived
