Enable Attribute Defaults in User's Personal Preferences
A big enhancement for the end user would be the ability to set preferred values for many of the attribute fields which they encounter during the creation wizards.   For example,  in a system where the WTParts or WTDocuments have custom business attributes such as the Business Unit,  or the Plant,  or the Change Task has the OOTB field for Assignee and Reviewer,  etc.,  it would be a time saver if you can specify your own preferred values for these fields so that each time you create one of those objects,  these fields are filled in for you automatically.
We have cases where a user is uploading documents of one WTDocument sub-type all the time.   It would be slightly faster for them if that sub-type was preselected every time the Create New Document wizard popped up.
Or they create documents always for the same business unit,  so they have to choose the correct value each and every document that they create.
When you have many options in the drop down menu to choose from and you're creating many documents in the system from day to day,  this can be very annoying.   Having a "user preference" setting that would fill in certain fields automatically for the user would help tremendously toward user acceptance and efficiency.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
