Enable Cascading Attributes to handle Constraints
0 Kudos
Currently t is only possible to use cascading attributes when you have two enumerations.
In our environment we have location specific values for an attribute that must be handled in one big enumeration list and the values get distributed afterwards with high manual effort.
Idea is to make it possible to allow constraints dependent from an attribute value. In our case we could use location specific enumeration lists and reduce complexity and administrative effort to update cascading attributes regularly.
Such enhancement would enable us to use cascading attributes and avoid conditional constraints (which bring disadvantages like during Import from Spreadsheet etc).
2 Comments
olivierlp
Community Manager
Status changed to: Clarification Needed
Thank you @jmayer-2 for publishing your idea. However, we need more information as specified in the form you saw in the submission process. (questions below). The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
Please let us know within the next two weeks.
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What product & version are you currently running?
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
Additionally, I invite you to check out this topic where PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
olivierlp
Community Manager
Status changed to: Archived
We are following up on our request for additional information on your idea. In the absence of further comments from you, we are archiving your idea. You still have the option to post a new idea with all the details required.
Thank you.
