Should be possible to save-as 3rd party CAD format (NX, CATIA, SWX....) from Creo Parametric into the local workspace and chekin the file into Windchill using Creo Parametric WGM.
Should be possible also to open from Windchill 3rd party CAD files from Creo Parametric Workspace, assemble them and checkin back the Heterogeneous CAD assembly to Windchill (at the moment the file created using Unite Technology and checked in by Creo wgm are not correctly interpreted by Windchill and it's impossible to open them again into Creo or native application).
Using the UWGM and the 3rd party CAD solution, should be possible to open, modify and chekin the native data created by Creo Parametric Unite.
Implementing this feature no more 3rd party CAD license and UWGM license needed to collaborate with external suppliers in a Windchill controlled environment... smooth and simplified transition from 3rd party CAD solution to CREO + Windchill and finally enables users to work into a real multicad collaboration scenario within Windchill.
