In MPSE, we are having equivalent Occurrence tab to view but it is removed in MAPSB from Windchill 11.0M010/M020
JC - Product manager agreed to have it as Product idea.
In MAPSB, it is difficult to debug equivalent occurrences in case of discrepancies. Below are the few cases where we really look for that tab.
Below are the scenarios where we really look for that table in past.
1. When the structure is big and performance of scrolling / navigating between occurrences (When over allocated) is bad
2. When performance is bad while querying for Equivalent occurrences
3. When consumption status is showing wrong or it is not upto date.
Related PTC Case that I filed C13577384 - How to identify Equivalent Occurrence without querying "Select Equivalent Occurrence in other view
Shyam.
