When Control Characteristics are associated to Operations of Process Plan, they might be valid for one of the related mBOM but not for all. Similarly to associated documents or Processing Resources, Control Characteristics should give the possibility to be assigned Part Tags. When assigning Part Tags, Control Characteristics can be filtered using Part Tag Filtering.
