Enable Part Tag Filtering on Control Characteristics
When Control Characteristics are associated to Operations of Process Plan, they might be valid for one of the related mBOM but not for all. Similarly to associated documents or Processing Resources, Control Characteristics should give the possibility to be assigned Part Tags. When assigning Part Tags, Control Characteristics can be filtered using Part Tag Filtering.
3 Comments
olivierlp
Community Manager
Status changed to: Clarification Needed
Thank you for publishing your idea. We need more information as specified in the form.
Please let us know within the next two weeks.
Below the prompt questions.
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What product & version are you currently running?
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
mlasri
6-Contributor
Hi see below responses to the questions:
As a Windchill Master Architect, I belong to PTC Professional Services and I support MPMLink deployment at Volvo
Current Windchill version in Production is 11.1M020. Volvo roadmap is to upgrade to WC12.0.2 CY22H2
Filtering associated Control Characteristics according to related part selection (similar functionality as for Document or Tooling)
Master Process Plans are used to prepare manufacturing of multiple products. These different products require quality control checks in Process Plan which are defined with Control Characteristics. The definition of the Control Characteristics is dependant on the product but there is no possibility to specify it using Part Tag assignment (like it is possible to do for Document or Tooling).
Hope it clarifies.
olivierlp
Community Manager
Thank you for your idea and the information provided.
