If you have to edit multiple Objects you can select them and switch over EDIT --> Attributes to the
New Window "Attribute bearbeiten".
In this View it's not possible to edit an IBA Attribute and switch to next IBA Attribute (to the right) by pressing TAB Key on the Keyboard. If you press TAB Key the Cursor switches away from the Object into the Main Window of WGM or Browser.
The Function we miss in "Edit Attributes" is implemented in other Views. For example in "Uses" at WT-Part
Here you can TAB through and also Edit IBA Attributes (Like in Excel).
If you have also some IBA on objects and have to maintain attributes during Lifecycle that would be more convinient.
