A company should be able to make the decision to stop using a module within Windchill and remove it from the system, or at least disable it.
Right now there are ways to work around the problems but all aren't very well supported or recommended by PTC. They are given as "This is not guaranteed to work."
Though with persistent licensing it may not be an issue with upgrades it still feels as though you are locked into to never being able to get rid of any modules once they are installed.
I understand many modules are interlaced through several tables, and you don't always want those objects to go away, but there should be a consistent way to prevent future use of the module.
Example:
https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS210470
