Some customers, such as Raytheon have disabled the IMAP protocol in order to comply with EXIM mandates. It would be helpful if WPA supported other protocols such as HTTPS, RPC over HTTPS, or MAPI over HTTPS on port 443 so that WPA can connect to email inboxes using one of these protocols instead of IMAP.
