1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What version of Windchill are you currently running?
Windchill 12.0.2.4
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
It would be helpful if the Reporting domain in Windchill REST Services could be used in combination with PowerBI/ODATA. We want to use an OData connection from PowerBI to Windchill to securely extract data.
Right now we need customized domains to extract all relevant data (i.e. Workitems). If we could use the Reporting domain we can use our Querybuilder reports to achieve this without customizing.
4. What is the use case for your organization?
Securely using PowerBI for dashboarding of Windchill data. These reports are used by many users on a daily basis.
5. What business value would your suggestion represent for your organization?
Better performing integration to PowerBI, much easier to extract reports without customization.
