Enable Windchill search to support ‘pure’ latest iteration search when additional criteria is applied.
Current behavior: with latest iteration search is performed with State ‘In Work’ then all ‘In work’ objects are searched and later latest iteration filter is applied on it. If you search multiple objects, you will receive duplicated results (which would add up to a wrong search result).The system should be able to show only the real latest object (the “current”) and not the latest from all states.
So a "pure latest" search criteria have to be add to the search function in Windchill.
19 Comments
STEVEG
20-Turquoise
This has drove us nuts.  I whole-heartedly agree.  It is different in PDMLink from Intralink 3.4 and lower.  If I put a criteria of latest objects at In Work then if the object is at 2.2 at Production Released but 2.1 is In Work then I don't want that object to display at all!
cpage
2-Guest
Totally agree.  Multiple users have misunderstood search results, and costly mistakes were made. The actual functionality is different than users expect.  Practically all users depend on Advanced Search, and it is nearly impossible to explain this crazy functional issue to everyone.
TomU
23-Emerald II
It sounds like what you really want is a priority to the search criteria and then the ability to change that priority.
First filter for all lastest revisions, then filter for all latest iterations, finally filter for all 'Released' objects.
CaitlinWheeless
1-Newbie
I think this might already have been fixed.
I have the following objects:
Part 1:
Versions A.1, A.2, A.3 = In Work
Version A.4 = Released
Part 2:
Versions A.1, A.2, A.3, A.4 = In Work
Version B.1 = Released
I searched for parts that are in the latest iteration and in the In Work state, and got the following results:
Note that Part 1 version A.3 was NOT included in the results, which is what the original post seems to be addressing.
Whether or not Part 2 appears is set using the "Latest Version Search" preference -- but that is dealing with revisions, not iterations.
(And technically, specifying latest iteration is unnecessary. By default, all searches are performed against the latest iteration. The Iteration criteria is only necessary if you're searching for a non-latest iteration.)
TomU
23-Emerald II
This is actually very concerning if it's no longer possible to locate an object where both Criteria are true.  What if you really meant: 1.) find all "in work" objects then 2.) filter this set by the latest one of each?  We do this today for "latest" + "released".  Just because something has been revised to "in work" doesn't mean I should stop seeing the "latest released" version.  Either we need a "pure" latest search (as the idea suggested), or we need to set the priority of the search order (search for "A" first, then filter this by "B", and so on).  If the latest release of Windchill really does change this functionality, then we are in serious trouble.  Latest released data needs to continue to remain available from search, even if there is newer unreleased data in the system.
CaitlinWheeless
1-Newbie
So, for example:
"MyPart1"
A.1 = In Work
A.2 = In Work
A.3 = Released
A.4 = Released
A.5 = In Work
And you would want to search for the latest version of "MyPart1" that's in the "Released" state -- in other words, you want a search that would return MyPart1 version A.4. Is that correct?
One way to do it would be to search for Iteration=All and State=Released, but that search will return version A.3 and A.4. But I can ask the search team if they can think of a way that this might be handled.
TomU
23-Emerald II
Yes, this is how it works today (10.2 M020).  I want to make sure I don't lose that functionality.
TomU
23-Emerald II
What version are you testing on?  10.3?
TomU
23-Emerald II
By the way, I think this drives much more than just search.  If we have users who are only allowed to see objects that are released, they should still be able to find and display the latest version of those released objects in search, Creo View, structure browser, etc.
CaitlinWheeless
1-Newbie
I was testing on 10.2 M030.
But you're ok -- this didn't go away. I think the difference is latest revision vs. latest iteration. Searching for a non-latest iteration is more complicated.
For example, I created "Part 6" with the following version history:
A.1 = In work
A.2 = In Work
A.3 = In Work
A.4 = Released
     (Revise)
B.1 = In Work
B.2 = In Work
     (Revise)
C.1 = In Work
C.2 = Released
     (Revise)
D.1 = In Work
D.2 = In Work
D.3 = In Work
A search for "Part 6" returns the following:
A.4
B.2
C.2
D.3
Search for Part 6, Revision=Latest returns the following:
D.3 (In Work)
Search for Part 6, Revision=Latest, State=Released:
C.2 (Released)
-- Which is how you seem to be using it, and it continues to work as expected.
The potential problem would be in a use case where for some reason you iterated C.2 to C.3 and then put C.3 in the "In Work" state:
C.1 = In Work
C.2 = Released
C.3 = In Work
In which case, a search for Part 6, Revision=Latest, State=Released would return:
A.4 = Released
Which is likely exactly what you want!  But strictly speaking, the most recent revision of Part 6 to be in the Released state is version C.2. But since C.2 is now a non-latest iteration, it's ignored by Windchill search.
PTCModerator
Emeritus
Status changed to: New Idea
PTCModerator
Emeritus
TomU
23-Emerald II
Out of more than 3,200 Windchill product ideas, this one is currently ranked 7th.  It's been almost eight years since the  idea was created, and in all this time not a single response from anyone who works for PTC.  Clearly this idea is important to the Windchill community.  What is it going to take to get this behavior 'corrected' in the next version of Windchill?  Does someone need to start a working group???
mdrum
For me, what I want is the following behavior:
Part 1 History:                                         Part 2 History:
A.1 In Work                                             A.1 In Work
A.2 In Work                                             A.2 Prototype
A.3 Prototype                                          B.1 Prototype In Work
B.1 Prototype In Work                             B.2 PreProduction
B.2 Prototype
C.1 Prototype In Work
C.2 PreProduction
D.1 PreProduction Change
D.2 Production
Today, if I do a search with the following criteria:
State = PreProduction
Revision = Latest
Iteration = Latest
I get:
Part 1 - Version C.2
Part 2 - Version B.2
What I really want is just to get:
Part 2 - Version B.2 (because the latest revision/iteration of Part 1 is not at PreProduction)
Also, if I perform a keyword search on all parts, initially I would get both Part 1 and Part 2, and then, if I were to use a facet for "State" and select "PreProduction", I would only want to see Part 2, because I want to refine my initial search results further, not start a brand new search through the entire history of all objects considered in the search.
Finally, if I classify an object today as a BOLT at Version A.2 and then, at version A.3 I fix it to be a SCREW, when I do a classification search on Bolts, I don't want that part to show up in the results at an older version, because it's current latest version is a SCREW.
mdrum
As an addendum to my previous comment - to me the combination of:
Revision = Latest
Iteration = Latest
would be the same as saying "Give me the latest version"
Maybe that is what we actually need - is a "Version = Latest" option.  This way, if you want the absolute latest version in an object's history to be considered, and ignore all other iterations in the history, then this option could do it.
If you want to use Revision and Iteration as criteria, then you are looking back into history.  That would be an acceptable compromise in my opinion, because there may be times when you want to pull up older versions that meet certain criteria - but most of the time when I am doing searching like this, I'm cleaning up data in the system - so I want to know where all the parts are that are in a context that have never been released, and if I do a search on the initial "In Work" state, I don't want to get all the parts that started off at that state and have since moved on to released states, that defeats my objective.
TomU
23-Emerald II
@mdrum - YES to everything you said.
I wish the search criteria were applied in the order defined.  This would solve the problem of not being able to locate the actual latest version and bring so much more capability to the search tool.
Vikram_Sinha
We do have a future backlog to address the "true latest" concern, but we also have to acknowledge the fact that a majority of our customers do not want this change and are fine with the current behavior. A change in the current behavior would mean "regression" for them. As of now, there are no specific timelines available for this implementation, but whenever this gets implemented, the solution will have to be an optional one, like a switch, wherein the current behavior continues to be the default.
TomU
23-Emerald II
@Vikram_Sinha,
Thank you for responding to this product idea.  It's good to know PTC is paying attention to these.  I would like to respond to something you said:
... we also have to acknowledge the fact that a majority of our customers do not want this change and are fine with the current behavior.  A change in the current behavior would mean "regression" for them.
1.)  Has PTC really surveyed the majority of their customers on this one specific issue?  I've certainly never been asked about it, and I'm guessing the other 183 companies who voted up this product idea weren't asked either.  (Keep in mind that these 183 votes represent thousands or even tens of thousands of actual end users.)
2.)  Did the customers who were asked really understand the nature of the request?  Were they able to see what Windchill is incapable of doing today?
3.)  I don't think anyone on this thread is asking for the current functionality to be removed or replaced.  We're simply asking for some way to search for the required information.  This is very easy to do from the database but currently impossible from the Windchill user interface.  Maybe add an extra check box on the advanced search page or add a new user preference, but give us something that will allow us to search for and filter against the actual last iteration and/or revision of an object's history.
I really think much of the frustration with this is caused by the definition of 'latest'.  Windchill (apparently) uses latest to refer to mean "the latest among the stuff collected" instead of "the last one that actually exists".  There is a huge difference between these two.  Using @mdrum's example, I think most people naturally expect the bold items below to be the 'latest' iterations and the red items to be the latest revisions (and versions).  What is considered 'latest' should NOT change based on the search criteria, rather it should be fixed based on the objects history.
B.2 Prototype
C.2 PreProduction
D.2 Production
Yes, there is definitely value in being able to get the latest among a collection of objects (post filtering the search results), but right now it's at the expense of being able to actually find the objects we're looking for.  Somehow there needs to be a way to distinguish between what is being searched for and the filtering that happens after the results are returned.
@cpage probably said it best (emphasis mine):
Please reconsider adding this functionality to the next release of Windchill.  Thanks.
nsamardzija
Status changed to: Under Consideration
