Currently, the UI only allows the selection of one Project at a time when doing a share to a Project.
Scenario 1: We have a large number of documents that we require our vendors to train to and/or have access to. These are generally SOPs and Work Instructions. We will have a project for each vendor and would like to be able to share these documents and select all vendors at once.
