in the advanced search it is possible to use exponential prefixes when searching for attributes with units. E.g. 22 nF for 22 nano farad instead of typing in 0.000000022
In the "refine results" to do further filtering this the usage of this prefixes is currently not possible. So in this example the user has to type in 0.000000022 if he wants to use this as a filter in a search result.
To make the "Refine Results" more user friendly and to avoid mistakes caused by missing a '0' or have a '0' to much it would be great to have the feature of Exponential Prefixes in the "refine results" as well.
