In the renaming UI it is possible to enter new CAD file names which are longer than the given maximum length of 31 characters.
The validation of this value is done on server side after submitting the changes which leads to a conflict which is shown in the Event Management / Conflict Management dialogs:
Instead of being able to submit the dialog, the user should receive a validation error message straight away. This would be much more comfortable for the user.
