Enhance error message E-EC-UP-00171 to include subproduct/productid item name or item number if it exists (something to make the error msg point to the unique instance of the problem). This particular XML had material WIRE under 2 different subproducts.
We received serveral Class D XML files that included subproducts. The supplier made several errors with their proprietary data. Just having the material name with the substance name did not make finding the problem substance any easier. The files contained approximately 69 subproducts!
XML:
E-EC-UP-00171: Duplicate Substances cannot be contained in one Material. Material: WIRE contains Substance (CAS Number: PROPRIETARY, Description: PROPRIETARY) more than once.
E-EC-UP-00171: Duplicate Substances cannot be contained in one Material. Material: MOLD COMPOUND contains Substance (CAS Number: PROPRIETARY, Description: PROPRIETARY) more than once.
E-EC-UP-00171: Duplicate Substances cannot be contained in one Material. Material: FIPG TX-09 contains Substance (CAS Number: PROPRIETARY, Description: PROPRIETARY) more than once.
