When searching in Windchill for several subtypes of WTDocument in one step, it´s only possible to use the "Default View" for the search result. Here are the attributes "Created By" and "Modified By" not available. When searching only for one subtype of WTDocument in a search, it´s possible to use the "Default Document View", where the attributes "Created By" and "Modified By" could be used. The attributes "Created By" and "Modified By" should be available in the attribute setting for "Default View".
