The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Ensure harmonization in the error message when provided information exceed the limited length
The enhancement refers to the PTC TS Case #11255379: "NOT THE SAME behaviour WHEN maximum length for one field has been exceeded. Getting always the same explicit error message should be the right behavior." has been created.
https://www.ptc.com/appserver/cs/view/case.jsp?n=11255379
that has been closed with SPR
CS113275 with link = https://www.ptc.com/appserver/cs/view/case_solution.jsp?n=CS113275&lang=en
Reminder:
Three different behaviours are observed when maximum length for one field exceeded :
First behaviour: An error message displays that maximum length exceeded (exemple: in "New part" window put > 256 caracters ine "Name" field)
Second behaviour: No error message is displayed (exemple: Click on Expand-> Search tab, click on "Advanced search button", "Save this search" button, put in "Save this search" page > 256 caracaters)
Third behaviour: An Oracle error displays a french error message
so the enhancement consists in ensuring harmonization in such error cases.
thanks
Best regards
FredB
2 Comments
GregoryPERASSO
Salut Fred .
+1 sur ton idea ... je t'invite à voter pour les miennes   😉
a+
PTCModerator
Emeritus
Status changed to: Archived
