PTC recommend to not use same cache location for Creo and for 3 party CAD
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS131176
"Cache sharing between a Windchill Workgroup Manager session and Pro/ENGINEER, Creo Elements/Pro 5.0 or Creo Parametric session is NOT supported due to potential compatibility issues"
Today users who use both Creo and ex Solidworks need to use a script to set enviroment variable before starting CAD and workgroupmanager.
My idea is to create a new set of enviroment variable for WWGM.
