Currently there are no events available for programming showing that a subworkflow has been terminated or completed.
I'd like the main workflow to complete if all of its subprocesses are completed or terminated. Currently this can only be done directly in the Workflow Template Adminstrator but the backdraw is that this solution only works if the number of subworkflows has to be known at the time when you create the main workflow.
