Usually the customer copies(saveAs) from a Template which is stored in a Windchill Library.
From time to time the customer wants to copy from a product as well. The bad thing about this is that the customer already changed IBA values. The IBA values are order or customer related and they won´t match for the copied product(order) as well. Therefore the customer needs the possibility to exclude IBA values during the saveAs process.
There is also the requirement that the customer wants to keep specific IBA values after the saveAs. Therefore an include action should be also given.
This feature would generate a high value for many customers. I would suggest context specific preferences for excluding and including customer specific IBAs.
