The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Expand supported linkage between Weibull and RBD
0 Kudos
Currently the Weibull and Rayleigh distributions offer support to send failure data to RBD from the Weibull module.  Would like to expand these capabilities to include all common distributions to both RBD and Weibull.
4 Comments
LawrenceS
18-Opal
Are you using the Weibull nad Rayleigh Distributes within ProE/Creo/Windchill?  If so, where is this functionality available because I did not know there was this capability?
Also what does RBD mean?
jmoody
The Weibull and Rayleigh Distributions are part of the Windchill Quality Solutions Weibull module.  There is integration that allows us to utilize the BOM structure that is managed within Windchill as well as Critical Characteristics from Creo to perform a number of Reliability, Risk, and Safety analysis techniques.  We also have integration to kick off the change process within Windchill based on the results of your analysis.
PTCModerator
Emeritus
Status changed to: Archived
PTCModerator
Emeritus
