The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Expedite the deletion of big assys from the workspace when the model is still loaded in the CAD-tool
0 Kudos
Make it configurable whether the 3D model should also be deleted from the CAD-tool when it is removed from the workspace
Concerns Creo Elements/Direct Modeling 20.1.x with Windchill WGM 11.1 Mxx.
Example:
  • A 3D assembly with 1.600 objects in workspace
  • Delete 3D model from workspace
    • Model NOT loaded in CED Modeling approx. 20 seconds
    • Model STILL loaded in CED Modeling approx. 7 minutes
  • A assembly with 4.500 objects in workspace
    • Model NOT loaded in CED Modeling approx. 30 seconds
    • Model STILL loaded in CED Modeling > 25 minutes
      • There is no interaction with CED Modeling and WGM possible, they are not responding during this action
      • The Workspace is already empty, even if the action is canceled.
It is no solution to quit the cad tool before or to delete the 3d model from the session. a user can forget that before the action.
See Article: CS304890 Removing a large assembly from workspace takes longer
Case Details: C14752271
1 Comment
olivierlp
Community Manager
Status changed to: Archived
