The Export/Import of Type and Attribute is a good functionality in Windchil.
From Windchill 10.1 M010 they have still improved this functionalitty like we can Export your Global attributes, Global Enumerations along with Soft types.
But the drawback it has got is like we will be able to have the Imported Softypes (Owning Organization as "Site") only, It's not possible to Import the same as (Owning Organization as "Your Organization" name) .
If PTC enhances the current functionality to allow users to set their "Organization name" as well through loadfromfile that would be great.
Note:
That again make sense, because for example say a company is there, and they have 2 different Organizations and dont want to have the data's shared between 2 Organizations. So it's better if we have something, that if we have an option to load at "Org Level" too.
Your valuable comments/feedbacks are acceptable..
Thanks & Regards,
Arvind
