Export the Organization level Object Initialization Rules in bulk from Windchill PDMLink
After reading this article https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS35866&lang=en from TS I created this idea.
6 Comments
TomU
Emerald II
This is planned for X-26 (10.3 or 11.0) due out in December 2015.  See this Windchill roadmap video starting at around 18:50.
Marco_Tosin
Tanzanite
Thanks, Tom.
I think Ryan Kelley may update this idea marking to done in the next release.
ryankelley
Newbie
Jeffrey Zemsky‌ - confirmed?
JeffZemsky
Peridot
Walid Saad - can confirm for sure, but I believe this is part of the Business Administration Change Promotion enhancements targeted for X-26.
Marco_Tosin
Tanzanite
Jeff Zemsky,
could this idea be marked as a current functionality in 11.0?
wsaad
Garnet
Yes, starting with Windchill 11.0, Business Administrative Change Promotion will track changes (delete, update, create) made to OIRs in your system and allow you to export that set and deploy it into a target system. The deliverable is a package of the set of objects, whereby you could manage the package as a build artifact, allowing you to automate the process of deploying updates to your Integration/QA/Production Windchill systems. It also provides the flexibility upon export by allowing you to filter the set of OIRs based on specific organization container, application container, exchange container, or object type. So although it does not provide the ability to export OIRs regardless of whether they changed, I believe it addresses the main use cases. If you feel otherwise, please elaborate on the use case you are looking to satisfy.
