The addition of soft toes of WTPartUsageLink is a great addition to Windchill, however it is limited that only one Soft Type can be used per Parent Type which means that in our case where we have two soft types of Part that when related via a structure to a common parent part different IBAs need to be recorded and are unable to do so in the tool today.
Multiple soft types are possible but when creating the relationship constraint an error is thrown in an attempt to relate a soft type of usage link to a part type that already has a relationship constraint.
