The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Extend the WVS Job Summary with the information why a JOB FAILED
In the WVS Job Monitor (#Site #Utilities #Business Administration) the "Job Summery for Site" gives the admin the information, if a job is failed or not.
But the "Job Summery for Site" does not contain the information, why the job failed.
For the information why the job has failed, the admin has to select a single failed row and has to try to identify the error in the "Job Detail".
This may be possible if a single job fails, if you have a large installation where over 100 jobs fail per day, this is not acceptable anymore.
There may be several reasons why the jobs fail. e.g. the easiest may be that the file cannot be retrieved or the worker could not be started ....
In this case it would be very helpful if you could filter the listed objects for the failure reason for better error analysis.
Note: The "Job Detail" should of course not be removed by that!
The current functionality looks like that:
2 Comments
BrianToussaint
To piggyback off of this, the view should be customizable for the columns.  It would be nice to be able to add Job Start and Job End times to the table also.  There are times where I need to go back and look at a certain time to see what was going on at that time to see if changes to the system are working as planned.  Or if there were issues reported at a certain time and I do not get notified by the user when I can look into what was happening at the time, it would be nice to be able to go back and look at and sort by the times.
PTCModerator
Emeritus
